Ceramic coating
Ceramic coating
Post by mooreken » Wed Nov 15, 2017 12:57 pm
Mike, here is the company that I used to coat my headers.
Pro-Tec Powder Coating
6662 Columbia Park Dr. S. #2
Jacksonville, Fl 32258
904-363-2064
It is real close to Philips and Greenland Rd. off Greenland.
Re: Ceramic coating
Post by BlackSnake » Wed Nov 15, 2017 6:35 pm
Thx Ken, appreciate you following up on that.
Re: Ceramic coating
Post by BlackSnake » Thu Nov 16, 2017 8:44 am
FWIW, there's an outfit local to St Augustine that I may try. They have two locations, one on US-1 and the other on Dobbs Rd where they do the actual ceramic and powder coating.
I called them yesterday and they were very responsive to my inquiry. The price and turn-around time they quoted seems reasonable, so dropping the parts off on Monday and hope to have them back sometime the following week.
They're also going to weld an O2 bung onto one of the collectors, so I can run an AFR meter. Ordered an AEM AFR gauge kit with wideband O2 (LSU4.9), which should arrive this week, so I'll be ready to start serious carb tuning a few weeks from now.
Think I'm going to go with satin titanium finish. Posting "before" pictures and will post the "after" shots once done.
Custom Coatings & Restorations
2475 Dobbs Rd, St Augustine, FL 32086 or 3175 U.S. 1 #5, St Augustine, FL 32086
(904) 687-1991
Cntaylor@customcoatings.comcastbiz.net
Re: Ceramic coating
Post by Tom Wells » Thu Nov 16, 2017 9:15 am
Clearly engine porn :-c
Craig did the headers for the Zephyr. Three times: long story, not his fault.
The work was good and the price competitive.
I don't know how they have held up; haven't seen them since they were installed :))
Are yours stainless? They kinda look like it.
Re: Ceramic coating
Post by BlackSnake » Thu Nov 16, 2017 10:56 am
Ha ha...never overlook an opportunity to provide engine porn pics...:-)
I vaguely remember that sordid tale related to the Zephyr's exhaust system, but forgot who did the ceramic coat. Thanks for the mention.
Mine are mild steel, not stainless.
Re: Ceramic coating
Post by BlackSnake » Thu Nov 16, 2017 11:29 am
Tom, not being very fluent in Ford engines and associated PNs, what header gaskets should I be on the lookout for?
Ford installation pdf says E3TZ-9448-A Exhaust Manifold Gasket – available at your Ford dealer.
FordInstShtM-6049-X303X305Y303.pdf
(46.82 KiB) Downloaded 98 times
Re: Ceramic coating
Post by Tom Wells » Thu Nov 16, 2017 11:49 am
You axin' me about small block parts? No idea...
I use the Victor Reinz on my two cars, but don't know if that's good for the small block.
Wade's gone, sadly. He would have got the call from me. I guess the next in line might be Herb or Scott. I can give you numbers if you want to call either or both.
Re: Ceramic coating
Post by BlackSnake » Thu Nov 16, 2017 12:40 pm
Oh yeah, forgot you have size issues...something about "if it matters what gear you're in" ...;-)
Thx, I'm sure I can figure it out.
Re: Ceramic coating
Post by BlackSnake » Thu Nov 16, 2017 3:08 pm
Summit Racing says Fel-Pro 1415 is the PN I need.
Re: Ceramic coating
Post by BlackSnake » Sun Dec 17, 2017 10:45 pm
Thought I'd take the opportunity to post pics of the pipes reinstalled after ceramic coat...
