dead in ohio
dead in ohio
Post by pops »
I going to Ohio next week to get my car. Its hasnt been cranked in two years. I know I need to remove all the gas and change the oil and filters.
should i remove all the spark plugs and put oil in the cylinders then turn it over by hand. Any input is appreciated. Thanks Robret
Re: dead in ohio
Robert,
Voice from the past! Hope you'll go driving with us when you get back.
Not my forte; no suggestions here...
It would be good I think to limit the oil directly in the cylinders (if indeed you do that) to only a few drops. You don't want a lot in there - at least less than the amount that would lock up the engine. Maybe a small squirt of Marvel Mystery Oil or the modern equivalent.
Good luck getting it going. Maybe someone else will chime in (Mike? Ken?).
Re: dead in ohio
While putting a squirt of oil in the Cyls. is not a bad thing I don't think it is necessary unless the plugs are really easy to get to. If you do decide to do the oil in the cyls. along with a squirt of WD40, let is sit a while, no need to turn it over by hand just leave the plugs out and use the starter, then I would put new plugs in it just because you are there.
Gettings the gas out of the tank is a good thing. More importantly I would pull the carb bowls and clean. With the alcohol the bowls are always vulnerable to corrosion and a stuck needle. (this is for all carbs but especially Holleys). If you have not taken off the fuel bowls before and covered with a light film of grease, I would get new gaskets as the ones on the bowls will most likely self-destruct on removal.
If there is a fuel filter I would change that too....maybe twice. Once at first and one after a drive around the block a time or two...Depends on what you find after the test drive.
What you listed to do is good. My brother and I started the Triumph that we restored after it had sat for about 15+yrs doing these things and of course Points and such...It is a good feeling to bring one back to life after a long sit.
